Someone brought in an EL84 Stereo Integrated amp. I've never seen this model and can't locate a schematic diagram. There is no model number on the chassis or the front panel. Just "Precision Electronics" on the rear panel. It appears to be identical to this one:Appears to be similar to other EL84 circuits. Of course I'm never lucky enough to get something that hasn't been altered. It appears a metal oxide resistor was added between the screen grids and the cathode resistor. I presume they were trying to lower the screen grid voltage on the EL84's which are daisy chained together. The resistor which measures 9.4K, overheats when full line voltage is applied and starts to smoke. Not sure what the original resistor value was since the color bands are pretty much burned off.
The screen grid voltage is approximately 250VDC with the resistor in place. So it's trying to dissipate 6.65 Watts which is too much for that resistor. If I remove the resistor, the screen grid voltage jumps up to 326VDC. The plate voltage remains about the same at 370-375VDC. So not much change there.
