bfotk
bfotk
It's been quite a few years since I played with this charming Little Jewel. I just plugged it in and when I turned it on, the 5Y3 rectifier flashed brightly and the fuse blew. A second fuse did the same. I went out and got more fuses...
I pulled out the 5Y3, put in a new fuse, and turned it on. The output tubes and the adjacent 12AX7 lit. The 12AX7 that's covered by a metal shield did not.
Not having another known good 5Y3, I inserted a 5AR4 (which I believe but cannot prove is good). I got the flash and blown fuse again.
Suggestions (aside from putting it up on eBay as-is)?
