Ground Loop problems
fishookred
Member
I was recently trying to digitize a few records of mine when I came across a problem. there was a noticeable "electric" sound in the recording when my computer was turned on. I have everything plugged into a tripp lite iso- which I hoped would solve the problem but didn't. i assume it is being created by the computer itself. anyway I purchased a metra rca ground loop isolator from amazon. will this solve my problem without affecting the audio quality or am I overlooking something else entirely?
Thanks
Well, your computer can create a large magnetic field about it. That field will disturb the phono cartridge if the turntable is close enough to the computer.....
Don't know what you're using for a preamp and such, but I digitize with a DIY preamp and Emu interface. What I do is run Visual Analyser (free) in spectrum analysis mode and then fiddle with ground switches, plug locations/polarities and component positioning, until every bit of hum is gone. Or at least as good as I can get it. No idea if the isolator will help as systems are different and the reasons for noise and hum problems are myriad.
Where is your ground wire from the turntable attached? If you are using the onboard/motherboard sound card, that may also be your issue.
