Do most turntables connect their ground wire to the internal turntable chassis, or is it connected to the signal (coax) ground? Or both? I'm building a phono preamp that will have its ground post connected only to the chassis and earth ground. Signal grounds, including the input/output RCAs, are isolated from this. It's not clear to me whether this is what turntable manufacturers expect, or if the ground wire is intended to connect to signal ground at both ends.
Jack
Jack
