cubby01
aka Buck
Anyone got a min to answer a question about tube amp grounding?
Chassis is just an aluminum top plate. I'm going to use a 3 prong IEC plug socket for wall power. PT secondary HT has center tap. For 6.3 secondaries do not have CT and I will use artificial CT (couple of 100ohm resistors).
What should the IEC socket ground be connect to? Just the chassis? Or just to the secondary CT, or both?
Is there a best place to ground the 6.3 artifical center taps? (I have two pair of 6.3 secondaries, I'll use one for rectifier and one for the other tubes I think.)
The input jacks I have are not insulated. Should the jacks be isolated from the chassis?
Thx.
Thx.
