HiMcDunnough
Member
hi all
Here's the setup that I'm having problems with
Pro-ject phono stage (12ax7a)
Lector ZOE preamp (no phono stage), (Telefunken 12au7 tubes)
Adcom GSA-555.
- I've been using a Cambridge 651p (budget ss phono stage) with zero problems.
- the pro-ject works as it should for five minutes or so, after which I get a low hum, like a grounding issue.
-I've disconnected and reconnected it several times, taking care to ensure the ground connection from TT to the phono stage, but with the same results each time.
-switching back to the Cambridge resolves the issue
-Since I don't have grounding issues at all with the other phono stage I'm wondering if it could be something tube related. Is 12Ax7a to 12AU7 a bad match?
Any insights? Any help would be greatly appreciated
Thanks for reading
Adcom GSA-555.
Thanks for reading
