The GRS 12PT-8 is a 12" prosound woofer that is optimized more for bass extension than for
very high efficiency. This is a rare type of driver since most prosound types start to roll off
usually above 50 Hz and often far above there.
Note: TODAY I NOTICED THAT THE GRS Xmax SPEC ALREADY HAS SOME OVEREXCURSION IN
THE SPEC, I SHOULD HAVE REDUCED THE AMOUNT IN THIS PROGRAM TO 1.2. FOR NOW
JUST ASSUME A 150 to 200W LIMIT AS MAX WITH MODERATE DISTORTION FOR VENTED.
SEALED WILL PROBABLY TAKE 250W PEAKS AS SHOWN ALSO WITH MODERATE DISTORTION.
Here are some sims in Unibox:
Advertised parameters entered:
======== 4 cu ft VENTED BOX TUNED TO 35 and F3=35 OBVIOUS B4 ALIGNMENT:
==== USE 2 cuft for a B6 ALIGNMENT Fb=35 AND 6dB BOOST AT 35 TO RECOVER OUTPUT:
==== OR PERHAPS ROOM GAIN WILL BE ENOUGH FOR NICE TIGHT SOUND. RESPONSE WILL
==== LOOK AND SOUND MORE LIKE A SEALED SYSTEM. 3 cu ft IS A FINE COMPROMISE
WOOFER EXCURSION:
======== 3 cu ft VENTED BOX TUNED TO 38 and F3=39 CLOSE TO A B4 ALIGNMENT:
==== 3 cu ft VENTED EXCURSION
======== 2 cu ft VENTED Fb=35 F3=49 NOT THE BEST EXTENSION BUT B6 TYPE BOOST WILL RECOVER IT
======== CLOSED BOX IN JUST OVER 1 cu ft THAT'S SMALL, USE EQ TO RECOVER DEEP BASS IF NEEDED:
==== F3=68 Hz, NOT VERY LOW BUT IT WILL TAKE SOME EQ
==== SEALED EXCURSION AT 250W and 1.5X OVEREXCURSION ALLOWANCE
WOOFER EXCURSION:
