JRH99
A friend of mine purchased a Grundig KS400U and asked me to help with restoring the radio. I could see that someone had already been in there and had replaced the main filter caps. I always hope I find it untouched, as you never know what someone may have changed. I brought it up slow on the variac connected to my DBT. No shorts but I observed no sound on the left channel. I pulled it from the console to test on my bench. I noticed higher than expected voltage drop on the selenium rectifier, so that has been replaced with si bridge.
I found that I have low voltage on V5 (left channel ECL86 output tube). I have tested the tubes and switched between Left and Right. I have tested most of the resistors, replaced a few caps, and other than some caps that were testing bad, I am not finding the issue.
I am now thinking I may have a bad output transformer on the left channel. I tested the voltage on the blue output line on T3 and T2. I have the same low voltage (4.5v) on that T2 line as I see on pin 9 of V5. On T3 it has the correct voltage at about 260v, same as it should be at pin 6 of V6. Attached is a marked up schematic with my voltage measurements in blue.
I hope I am wrong about the output transformer, and that someone here with more experience than me will see something I missed. I appreciate any feedback you may have, good or bad.
Thanks,
Thanks,
