Guitar amp 12ax7
Tungsol
NOS mullards, amperex and telefunkens are the usual list of characters recomended for audio applications. Are you looking for different characteristics in guitar preamp tubes compared to a typical audio 12ax7 linestage or phono application. Any recomendations for the best sounding 12ax7 tubes for guitar amps?
Thanks.
I always looked for Mullards and Telefunkens for there sweet break up in guitar amps. For clean stuff like Fender amps the RCA's are very nice.
If you need gain to overdrive a later stage or the poweramp, I've had some really good experience with an old (very old) Korean 12AX7. I didn't even know they made 12AX7 in Korea, but they do, and they sound amazing. The glass is thin enough to make me worry, though...
If you're using a high gain guitar amp that overdrives the preamp or that uses a tube preamp for distortion-- in the case of a Vox or Marshall Valvestate/Valvetronix amp-- I've found that the sound of a 12AU7 absolutely destroys any 12AX7 I've heard, even if it wasn't originally what the amp was designed to use.
