FranzS.
Hello,
I just got gifted a Harman Kardon Citation 16A and the guy I got it from said it has been partly revised 4 or 5 years ago and then worked fine but one channel kept dropping out under load so he retired it.
Now I plugged it in upon receiving it today (did a visual check for leaking caps or similar) and the Channel A (left) powered on with a slight "click" but Channel B (right) did not show any signs of life.
I then looked on the bottom accessory hatch again and found a blown Fuse (2A 250V Slow blow) and I thought ok lets swap the fuse from Channel A to B wich unfortunately led to another Blown Fuse.
I hope the Post is in the right Forum as this is my first time posting here.
Greetings from Germany,
Franz
Franz
