z-adamson
Addicted Member
You should be firng these up with a 60watt bulb and the fuses going to the driver boards pulled. Then with the fuses in.
When properly set up each heatsink should be at about 88 degrees when fully warmed up and an ambient temp of 65*.
If you find youself having to turn the trim pots much past the center position, something is wrong. At full health, the pots should be very close to center.
Here is a pic of a 200 I just finished restoring. I am monitoring bias, offset and temp.
