1. Many amplifiers CLAIMING to be "common ground" turn out to have resistors in the ground path that makes the amplifier unsuitable for use with Polk SDA speakers. The resistors can be bypassed with a jumper wire between the left negative binding post and the right negative binding post. Some, but not all Adcom, Parasound, and my Aragon 8008BB are built like this, and various others are sure to be similar, I just haven't looked at the schematics. MEASURE the resistance from left negative to right negative with an ohmmeter. Less than one ohm is suitable. More than one ohm is questionable. Twenty ohms (a ten-ohm resistor on each channel's ground circuit) made my SDA 1Bs unlistenable. Of course, "bridged" or "balanced" amplifiers CANNOT be common-ground, along with certain Carver amplifiers that have one channel inverted.
2. Not all SDA speakers are compatible with the isolation transformer. The first three generations of SDAs CANNOT use the transformer, the last (newest) two generations can accept the isolation transformer. Most but not all of the fourth and fifth-generation speakers use an interconnect with a pin and blade terminals, the previous generations were (usually) blade/blade terminals.
3. While the third, fourth, and fifth generation of SDAs do not need common-ground amplifiers for treble when bi-amping, the first two generations will (and you'll have to modify the earlier speakers to biamp.)
4. The Polk SDA speakers tended to be 4- or 6-ohm loads, so the 92 db sensitivity is misleading. They're more like 92 db with 2.83 volts, which on a four-ohm speaker is two watts of input power. Knock off 3db for 1-watt specs.
5. There's aftermarket and Polk support for some of the SDA drivers and other parts, and the Club Polk folks are advocating for various crossover and driver-mounting upgrades. In sum, the speakers can easily be hot-rodded to sound better than new. I know this because I bought my 1Bs back in the mid-80s as the original owner. Replacement caps, an inductor or two...mine sound better now than they did with the original parts.
