Hypothesis: Solid wire sounds clearer than Stranded wire. Completely replacing the power supply and Signal out wiring with 12 AWG solid wire (Signal-in replacing with 18 AWD Coax). WHY? Read on -
I have several power amps (and high power receivers) which have undergone extensive A-B testing in my system, and after messing around with solid and stranded speaker wire and interconnects, it seems that solid wire in my system (at least to my wife's and my ears) increases the overall sonic clarity.
This is not to rehash the Solid vs Stranded wire debate or throw personal opinions around. To determine this for myself, I decided to rewire my DH500 with 12 AWG solid as mentioned above as a first step to my DH500's rebuild. Yes it is quite a bit heavier than the 18 AWG stranded that was used, so it should make a difference just due to the heavier gauge alone.
This amp was compared extensively and exhaustivly (prior to rewiring) with the following Power amps (and a receiver power amp section):
Carver AV-705x (two channels driven)
Counterpoint SA100
Technics SE-A5
Sumo Andromeda
Sumo Andromeda II
Pioneer SX-1980 (Power amp section only)
Using the following speakers:
Yamaha NS1000M
Magnepan MGIIIa (heavily modified frams and X-over)
A home made pair with true 360 degree dispersion
I do plan to continue the upgrade with capacitor replacements later. Just wanted to do the rewiring and see if there was any audible change before I took the next step. Am also changing the binding posts with heavy duty gold plated ones and input RCA connectors with higher quality gold plated ones.
Hope this is interesting for some and you will have some suggestions for me.
Thanks!
Counterpoint SA100
Technics SE-A5
Sumo Andromeda
Sumo Andromeda II
Yamaha NS1000M
Thanks!
