JUst tried the correct start procedure and no go. I am going to go get some oil and se what happens.
Like was mentioned, make sure the tone generator isn't bolted down. That will stop it from moving. Also if the tone generator is moving and you aren't getting any sound make sure some of the stops are pulled out. and the pedal is depressed.
Chad
Just found this site. It has a lot of schematics for he organs.
http://www.captain-foldback.com/Hammond_sub/hammond_schematics.htm
The tech siad there are two problems. One is the tone generator needs an overhaul - it was moved when not locked down - he thinks it was actuall droped. ALos, there is a problem with the smaller 44-1 amp. I could fix taht, but the other is over my head. He showed me some of the damage. It's ugly.
Yes that does help and will look in the daylight this weekend.Look under the generator - under the board where the generator is mounted. There are four "bushings" with a nut. You'll see them. They are about 1.25" diameter and brass. Mine had a flatt on one side. Tighten the nuts and that will bolt the generator down. Hope this helps.
What type of oil do I need. The tone generator definately sounds "dry" and could use some oil. WHere do you get the oil?
This thing is a beauty, maybe it will just go inside and I'll even take some lessons. Yep, if I can get this working correctly, that is what is going to happen.
Well, Looks like I am going to join the bonehead club. This organ needs about $300 in repairs. I can get many different organs of CL for less and they work. So this one is going to be project. Anyone ever converted one of these to a monoblock amp? Schematics anyone?
Thanks!!!
