Harman/Kardon 330C - speaker terminal replacement?
davstev
Well-Known Member
Hi all, I picked up a H/K 330c, in decent shape, with just a few issues.
One of the issues is that a whole row of speaker terminals is wrecked and needs replacing. This must be a common problem, they are pretty flimsy. I have disconnected them and taken the broken mount panel out too. There's now just an open rectangular hole and some wires.
Anyone know of a decent replacement that will fit in the existing rectangular cutout hole on the back panel? Ideally a drop-in replacement? An upgrade of sorts?
thanks,
David
I've been looking for some posts to use for that purpose. I think they need to be skinny though to fit in the space of the original post. What I've seen seems a little too big to fit 4 posts in that space. If you find some skinny posts please list them here so people can see what you found, thanks
Here's what I did: These are banana plugs. It seemed to work ok, mounting the banana plugs firmly inside holes drilled into Sintra (plastic). I should be a bit concerned about the plugs touching each other but for now they seem ok. I might oneday change this again. It's ok but they do stick out...
