Dom123
Well-Known Member
Hi Everyone,
I bought a cheap HK430. Knobs are completely wrong & annoyingly the volume potentiometer has been replaced with a wrong value one (but additional resistors added) and so as a consequence the contour (loudness) doesn't work, even though the switch is working correctly.
Also changed all lights (dial, screen, stereo, & power on) as only one dial bulb was working ! Was pretty easy, so pleased about that. Installed LEDs in the dial screen & 8V incadescents elsewhere
The amps works well and seems to sound good. Bias is good. I intend to recap it but for the meantime I have dialed it to 20mV across an emitter resistor on each channel.
My concern is the very loud snap explosion when switching it off because I don't want to damage the tweeters on my speakers. It occurs on both channels, independant of volume. Switching on is quiet though, with no drama.
My intial thought is the snubber capacitor across the power switch must be defective but I can't see one.
Can anyone advise me if there is a snubber, or if there could be another thing to look at ?
Can I simply add one (X2 Safety cap) across the wires soldered to the switch ?
My other question is that on DBT the bulb (60W) is dimly lit all the time, whereas on most of my vintage amps the bulb tends to go fully out. Is this higher current draw related to the dual power supply configuration ?
