Hmm, I'm not really sure what I'm looking for on these solder joints but they seem pretty solid to me. I can't seem to find any suitable replacements and the closest available is the KSC1845FTA. I've seen reports on other threads of these being used successfully on HK430s so I think I'll give this a try unless there are other suggestions.
You really need to look with good light and under magnification, esp if you're older like me! But the fact that the capacitor seems "loose" says that something is happening there, whether that's a instable solder connection or a corroded leg on that cap. If you can keep a finger on the cap and wiggle it while you're looking at the solder side, you may see one of the legs below moving.
Place a heat sink on the leg you are working on. Place it towards the top, where it ends and the plastic starts.
This is what heat sink looks like. If you dont have one, improvise.
https://www.amazon.com/H-2SL-Goot-H...t=&hvlocphy=9003181&hvtargid=pla-441407903450
You can try the F, but I also gave you other, better transistor options. They would work, but you have to adjust their orientation i.e. make sure the correct leg goes into the correct hole.
That's cool, I don't own a heat sink, but I have worried about overheating components. This looks like a great staple of a hobbyist's toolbox.
OK I can do this first. I don’t have this heat sink but I can order one. Just to make sure that this should be attached to the leg on the top of the board and the retouch the solder on the back? Would it be necessary to desolder and resolder or apply any extra solder?
Finally is this one you suggested instead if this doesn’t work? I’ll just need to figure out how to orient the legs because it is different from the stock one?
https://www.mouser.com/ProductDetail/Central-Semiconductor/MPSA18-PBFREE?qs=u16ybLDytRZgZ5NNQU6fnQ==&mgh=1&gclid=Cj0KCQjwmIuDBhDXARIsAFITC_6BtKsHLE3hNSAiGHVg1NZT5ggMwA1pEqzIsZBZyIR0pWn3QUf2SAoaAo-tEALw_wcB
Yes, apply the heat sink to the legs at the top. It'll absorb heat and prevent most of it from getting to the component itself. It's a good idea, but it also depends on your soldering technique. If you're quick enough and you're dealing with a cap or transistor that you might replace soon enough anyway (and don't want to wait for the heat sink to arrive), I wouldn't say it's strictly necessary. But if you're the type that lingers in your soldering, which isn't uncommon for people newer, it's definitely a good idea. But it's never a good idea to linger very long anyway if you can help it, even with a heat sink, because you can lift a solder pad from the board if heat is applied for too long.
As far as desoldering, not really necessary. If there's a fair amount of solder there, you can just touch it up. if there's not much there to reheat, you can add a bit more. Of course, it never hurts to just heat the connection suck up the old solder if there's any doubt. Sometimes the old solder just looks bad/different, in which case, it probably would be good to just suck up the old solder and add new.
The transistor terminals (E, C, B) are labelled on the PCB,
but it's always best to verify because sometimes the PCB labels are wrong (whether it's polarity of a capacitor or transistor terminals) - don't always trust the PCB labels. You can look for the old transistor P/N, find a datasheet, and verify the order of the legs and that it matches the PCB labeling. Then look at the leg order/ID of the new transistor, and make sure they go to the right place. Sometimes, you'll have to swing/bend a leg across the other legs in order to get it to the right place. If there's any chance of contact between legs, it's a good idea to put some heat shrink or wire insulation on the leg that's bending across the others to insulate it from possible contact.
When you strip a wire, you get bits of wire insulation with no wire inside. I typically keep some of those around to use as insulators in such cases - just cut to required length. Saves you from having to use really narrow heat shrink.
