JB8
Well-Known Member
Hey all, it's been a while, back at it!
I'll keep this brief. When I first tested the unit it had a blown right channel fuse (the fuse that sits next to the main filter caps) along with the fuse on the underside for the same channel (FU3), both 3A. I replaced both fuses, removed and tested the output transistors, reinstalled them and swapped out Q421-422 (458's that I would eventually have swapped out regardless). Using a DBT everything looked good but I didn't fire up the unit under load... I then swapped out the Main Amp caps (6) along with the main filter caps (4). DBT after the new components were installed looked good so I hooked up some test speakers and fired it up still through DBT. Everything seemed fine but I hadn't engaged the speakers. I then pulled it from the DBT and powered it up, all good until I engaged the speaker button and "shortly" thereafter both fuses blew again. Dead right channel, left channel sounds fine.
The speaker fuse for the right channel has not been blowing and testing the transistors across the main amp and tone preamp with DMM didn't reveal any glaring issues but I know those 1344's can be problematic at times. It's been a while since I've attacked this kind of issue so I'm reaching out to this squad for some help. The issue is typically right there in front of my face but I always appreciate the assistance, thanks in advance!
