xrayspex77
Can't find the thread where it's explained but on the HK730, C405/406 are part of the Slow Start Circuit.
From the last Post in this thread https://audiokarma.org/forums/index.php?threads/hk-730-one-channel-slow-to-warm-up-question.168496/
"In this circuit, the final voltage across the cap is set by the voltage drop in the be junction (for Q405) and the voltage drop in the diode (D403). Assuming 0.6V for each, the starting time would be 6.6 seconds:
dt = RC dV/V
R = 1 Meg Ohm
C = 220 uF
dV = 1.2 Volt
V = 40 Volt
The starting time you get is close to this theoretical value, well within the tolerance of the electrolytic caps.
As you said, 5.5 seconds in one channel and 6.0 to 6.5 seconds in the other channel is... close enough."
EDIT
The HK430 appears to have the same circuit
dt = RC dV/V
R = 1 Meg Ohm
C = 220 uF
dV = 1.2 Volt
V = 40 Volt
EDIT
