There's a great question just asked: the HK 730 and HK A-402 power amp stages are very similar; the Harman Kardon 730 receiver's PHONO stage, when recapped, is awesome; is the PHONO stage in the HK A-402 integrated amp the same as the one in the 730?
Let's take a look:
The HK 730 PHONO stage (from the Harman Kardon 730 service manual):
The HK A-402 PHONO stage (from the Harman Kardon A-402 service manual):
Answer: yep, those are nearly identical. Same design, same semiconductors, mostly-same passives... just minor value differences.
I'd say "if you like the sound of the PHONO stage in the 730, then you'll find the PHONO stage of the A-402 to be (effectively) identical". That said, the TONE section of the two units are different, so the overall units will sound a little different.
Let's take a look:
