After a full recap of the tuner board, I noticed the FM meter is stuck at full strength (this was not the case prior to recap it adjusted according to the FM station strength normally prior to recap) and does not budge even between stations with no reception. Also, the muting button doesn't mute between stations likely because the meter is showing everything as full strength. Additionally there is no change in the meter strength when adjusting trim pots VR351 and VR352. I double checked and all capacitors appear to be in the correct orientation and correct capacitance. Could a transistor or other component have failed during this recap process? Any thoughts or advice would be appreciated. Thanks!
