Zeus12
Greetings Audiophiles,
Started the recap/restoration of the HK 730. Those little popping/cracking sounds were getting on my nerves.
I started with the Power Amp PC Board and so far I have replaced all electrolytics on the board with Nichicon UKL Series, and the Q401-406 with KSC1845 (F) -- all according to @dlucy wonderful restoration.
Right Channel:
Also cleaned the pin contacts and put new thermal compound (Dow 340) for the output transistors:
Power Amp NEC Output Transistors
I have an issue with the BIAS on the Left channel (VR01). I can only get it to around 14mv. The right channel is Biasing OK. Yes, I know I should have replaced those flaky trimpots. Inventory mistake.
I left both channel at around 14mV then and have been listening to it for a couple of hours now and NO MORE POPPING SOUNDS!!!!
So those original 2Sc1400´s were the culprit!! Thanks again to @dlucy explanation:
the 2SC1400 diff amp small signal transistors on the power amp boards have “gone noisy” in the second hk730 I’m working on. They are producing very loud crackling that begins at startup, occurs randomly, not tied to control knob adjustment, not specific to any function selection, and unaffected by volume control.
replacing them with hfe-matched KSC1845F eliminated the crackling, so these 2SC1400 were noisy.
It looks to me like that VR01 is the culprit (the metal part looks way too bent compared to the other one) so I will order 2 new trimpots from Mouser. Can I use it in the meantime? Should I change the BIAS on the other channel to the original specs (35mv+-5) or leave them both at around 14mv where they are now?
Cheers!!
Right Channel:
So those original 2Sc1400´s were the culprit!! Thanks again to @dlucy explanation: the 2SC1400 diff amp small signal transistors on the power amp boards have “gone noisy” in the second hk730 I’m working on. They are producing very loud crackling that begins at startup, occurs randomly, not tied to control knob adjustment, not specific to any function selection, and unaffected by volume control.
Cheers!!
So far it has been running GREAT. Heatsink is a lot cooler to the touch than before. I´m sure that old thermal compound paste wasn´t doing it´s job. AND NO POPPING NOISES
