JB8
Well-Known Member
Just picked up my first 730, stoked! I've had loads of 330c's and 430's, even picked up a 330B the other day, but wow, I was so excited to get this 730 even though its condition was the dreaded "untested".
I'll cut to the chase here. The left channel is blowing it's fuses. When I first plugged the unit in to get a baseline it was clear the unit hadn't been cared for lately - really difficult to turn the dial knob and function selectors, dial point light out, most other lights out as well, but, the signal meter is working, stereo light coming on appropriately, so with fingers crossed I attached some test speakers and got great clear sound from the right channel, nothing from the left across all functions. I then pulled the case, pulled the faceplate and started dusting and cleaning pots and push buttons. At this stage I hadn't noticed the blown fuses (it had been a while since seeing a blown slow blow, the element was still intact so at first glance the looked fine, rookie move!). After cleaning I did a quick continuity test on the fuses and found the left fuses were burnt out. I had a spare set of fuses, popped them in hoping a replacement was all it needed, blew them out too.
Some of you may know me by now but I'm early on my path to learning troubleshooting across several brands (while also renovating a house and helping to raise two small wonders), so I still have some significant voids in my knowledge of process/technique, but I love this stuff and I'm committed to learning.
I have a DMM, a scope with one good channel, just built my first remedial DBT, using a Hakko iron and sucker, ready to get after this. I have 5 of the 2.5 A fuses in-hand with a Digikey order for more fuses, but would sincerely appreciate some advice on how to avoid blowing any more as testing occurs.
Thanks in advance, and you're welcome to those of you who like pictures, I feel like it helps tell the story.
(at some point someone at a repair shop super glued in a new lamp for the dial pointer, I'm still salvaging the part, still needs attention...)
