There is definitely no offset adjustment on the 800+
The caps to check for leakage are the 220 uF /16V , two per channel.
The input differential transistors are Qx41 and Qx42, 2SC640L, 50V NPN high gain (400 to 600) They must be matched. They are side by side on the board.
For bias, adjust VRx41, for 5.5mV across emitter of Qx47 and collector of Qx48. x refers to 3,4,5,6 according to the channel to adjust.
