Harman Kardon 930 Phono 2 right channel + STEREO light issue
jpreza
Hey everyone! I’ve had my Harman Kardon 930 since around 2017 and absolutely love the sound. I mostly listen to classic rock vinyl from the ’60s, ’70s, and ’80s—Beatles, Beach Boys, Zeppelin, Eagles, Duran Duran, and so on.
Recently, I noticed an issue with Phono 2—the right channel is very low. I prefer using Phono 2 since it’s right next to the FM input, which makes switching between sources super convenient. I should also mention that the previous seller said that it had been recapped recently (around 2016 or so).
My setup:
  • HK 930 receiver
  • Pioneer PL-400 turntable
  • Ortofon 2M cartridge
When I plug the turntable into Phono 1, both channels sound great—no issues. So it seems isolated to Phono 2.
Also, a minor quirk: the STEREO indicator never lights up on FM, even though I can clearly hear stereo separation in the signal.
Any thoughts on where I should start with troubleshooting? Appreciate any insights!
TIA....JP
phono 1 and 2 use the same circuitry so if phono 2 is fine then the issue would not be in the circuit itself but possibly dirty rca jacks, bad wire. dirty function switch.
check the bulb
