Phobosx
Phringe
Hi all. I have an oddball problem I was hoping someone may be able to help with. I have a Harmon Kardon Citation 11 Pre-amp. It has been working fine but earlier today I turned it on and one of the meters on my Amp pegged. So I turned it off and checked the cables. Turned it on again and same result. I pulled the Pre-amp out and measured the DC on the outputs. The Right Channel is 0 volts. The left goes to about 3V DC on power up and then starts to drop. After about 20 seconds it had fallen to about 32 mv DC. Luckily the amplifier isn't damaged.
Okay fine I think. It's older and some part (Transistor or whatever) has failed. I open it up and pull out the Pre-Amp board (See pictures). I then download the service manual (from 2 separate sources) and the pre-amp board in the service manual is different. The one I have has this part called "Computer Components" but the pictures of the pre-amp board in the schematic show no such part and is generally different (Different parts, labels, etc) than the picture in the service manual. The Service Manual schematic shows 3 FET's, This board has no FET's.
I checked the 4 transistors on the board (in circuit) and none show a short and measure as I would expect. I checked the electrolytic capacitors (only 4 per channel) and no shorts or opens. I measured each resistor for both channels and they are the same values between right and left. I checked the voltages from the power supply and they are all just about where they should be (+/- a volt or so). The problem channel has a connection for something called " + Control Voltage". The working channel has a connection for "Control Voltage Ground" The schematic has a line for "Control voltage" but gives no value. I don't see anything on the schematic called "Control Voltage Ground". I measured the resistance between the chassis and this " Control Voltage Ground" and its 50 K Ohms so, this is likely not tied to ground like the other NEG Voltage pins are. I Also measured the AF Input of this board on each channel and it's near 0 DC Volts. Now, if I measure between the chassis and this "+ Control Voltage" it's about 86 volts. If I measure between the chassis and the "Control Voltage Ground" it's around 66 or so.
My luck would be the problem is in the " Computer Components" module. The AF output and Output ground both go into this "Computer Components" module. I could probably de-solder this and maybe open it up but Id rather not go that route right away as I may damage it.
Has anyone run into this type of thing before? Any idea how to check this? The schematic in the service manual does not match the circuit on my board so that information is probably not very useful.
Thanks
Thanks
