Harman Kardon Citation 16A
MickP
Hi all hoping for some advice. I am currently working through my citation 16A power amp recap and refurbishment. I need to replace both Dual NPN differential pair transistors on the driver boards marked as Q1. They are marked with a part number SD3119724 might be Motorola. Can’t find an alternative replacement anyone who has refurbished or has knowledge on the Citation 16A able to help with a substitute? Would be much appreciated. Cheers MickE0C1323A-5A1C-40C2-AF2A-7A4D00DEFF02.jpeg
According to the manual Q1 should be an MPS U10.
that is the 16. The 16A Q1 is a differential pair. I would think a matched pair of high voltage transistors would work - 2n5550 or KSC1845 or 2SC2240, but haven't worked on one, so caveat tech.
Oh - welcome to AK.
Closer look at schematic, collector voltages runs (indirectly) off a 10 volt supply, so no restriction on high voltages. So can use lower voltage stuff like BC550, 2n5210, or other good quality NPN transistors. As always, be careful on orientation, and a piece of spaghetti type insulation if you have to twist leads around.
