Westy56
A symphony of paradox
how do you know it's only 150W at 4?
Old foggy memory.
Steve
I've seen the 150wpc at 4 Ohms somewhere, too. The amps per channel figure is close to double by your specs. My 19 is original & I've always used fuses as a measure of care. I may try recapping all but the PS filter cans,any thoughts?
and hopeful I can get to putting them in soon but the I have several projects on the go right now and some of them relate to the real world. These are for C1 & C6 but I also got several more for the Citation 17 Preamp and I also have a HK730 that I use to use before I bought my Citation gear. I wish I could have hoarded more but I am also upgrading some vintage Braun L-910s http://www.audiokarma.org/forums/showthread.php?t=428692 and my play cash only goes so far. I think I paid close to $100 just for these 4 caps but the 470uf were double the 100ufs ($60 & $30). I also want to replace the analog input jacks because they are loose. I had been trying to make my Audioquest interconnects but the left cable kept cutting out. I thought I was soldering it wrong or something. I did the terminals 3x & then realized its the wiring on the 19's input jacks that are loose.
to know the difference :screwy::lmao:Thermostat wire will have the finest detail and least sibilance!
UGH!:sigh: I am waiting for some copper crimpers to come from Parts Connection to couple the wires back to the Driver Boards otherwise I may just end up soldering them back to the terminal posts. I tried to using something else but the connection was too loose. Hopefully tomorrow. Its killin me to not have had music all weekend - at least descent music.Great pics of your work! Fire that thing up & tell us what it sounds like!
But, hey, thanks for the compliment, i appreciate it.Nice looking work. :yes: Do you really want to leave the bridge switch?
Steve
Good point. I could leave the switch there to fill the space but take it out of the chain. What do I do exactly? The black wires are going to the left channel Driver Board, and there is one blue wire from the left channel jack going to ground. They aren't even involved with the switch at all. The right channel driver board has 3 wires that connect to it coming off the switch and only one wire connecting the jack to the switch. So my guess is that i need one wire going straight to ground from the jack and the other 2 going back to the Driver Board? Most likely the upper white and red wire. Is that correct?
Yes, keep the switch. :stupid:
Nothings ever easy is it?
Steve
