If it is an analog meter, connect the minus or common to the chassis for the plant, screen and cathode and the positive lead to the pin on the tube. Reverse that for the grid. You will need to supply the negitive sign on the reading when you right it down in this case.
Shelly_D
First time measured on live circuit,radio shack analog meter,v7 3- 250v,4-220v,5-150v going to250v,8-48to50v that's the one redplating,now v8 that's going nice and I was able to bias with fixed switch and working meter:3-225v,4-225v,5- needle went to the left negative I assume cant tell the number thou,8-25v,did not do any more casue am exhausted, need to get better meter and will do exact try to post some pics
Thanks Shelly for guidance,that's great now I know what to look for could be that have wrong resistors installed letting higher voltage to pass to tubes?cheers
Did not get to check it yet ,need to find my discharging tool,would it mean that those two bias pots are bad or disconeccted,could they use deoxit?remember when before all that upgrading work, bias pots dont remember exactly which would make the meter flicker like crazy,now bad ones dont move,just to mention this citation ii is one of the first models with big ass meter and no vent holes on top of chassis,might be 60 yeras old,cheers
Wanna thank again for your help Shelly,after awhile I found two resistors coming from pin 5 tied to wrong turrets 14 not 15,this was causing redplating,thanks again
