runnin'
Hi, I posted in an existing thread in the solid state section, but on second thought figured I should start my own thread.
So the 395i, upon power up, pushes out the woofers of the connected speakers before they return to normal in about a second. Measuring dc offset at the speaker posts(all pots set properly) shows that the left channel starts off about -500mv DC before slowly climbing to between -58,-67mv where it moves around a little. The right channel stays close to -32mv. After 15 minutes, both channels are still at their above mentioned values.
I checked out the service manual on this unit from hifiengine, and it says that 32mv DC is the spec. Also, it shows where the dc offset trim pots are but adjusting them causes the left channel to bounce around but settle back at the 58-67 range. I did deoxit the pots beforehand, and then put them back at their original positions.
I'm reading that either input transistor pairs(can't find them) might be the culprits, or the main output transistors, which are on the heat sinks. Other than that, I can't find anything that looks like heat stress or otherwise damaged or failed components. I did reflow a few joints that looked like they might have gone cold, but with no success.
I've got a Harman PM 625 as well and it sounds really nice. The 395i plays fine but after I saw the woofers push out I'm scared to connect speakers to it. Does anyone have any thoughts as to what I might be looking at?
