ecluser
I think that you have a bad interpretation of the idling current adjustment procedure on the HK770 service manual. The manual says to measure the voltage at TP1-TP3 and TP2-TP3 and adjust for 24mV total voltage. If the circuit is perfectly balanced it will be 12mV/0.33 Ohm, or 36mA per power transistor, or 73mA of total bias current in the two pairs of power transistors.A reading of 24mV across the test points (TP1 and TP3 or TP2 and TP3) is equivalent to ~73mA, IMO, this can be reduced to ~10mV for a bias of 30mA.
