redpackman
I am working on a Harman Kardon PM665 vxi amplifier. Doing so slowly. I have come to understand that many times the adjusting pots, variable resistors on the main power amp board cause problems. I've removed two and they both seem to be shot. They are VR 401 and VR 402. The HK part number for them is 5101-6838875 "Res, semi fix 68K".
I'd also be interested in a couple other variable resistors if they can be found. VR403 and VR404 5101-4717675 "470" whatever that is supposed to connote.
Any help locating a reasonable replacement would be appreciated. Photo showing the relative size and pin arrangement below.
