kmp14
After seeing a little discussion here on the H/K Rabcos, I decided to get back to my disaster ST-5. It is in shambles. I am having a frustrating problem with it. Everything "looks" good, but the darn thing tracks slow, in other words the arm leads the carriage. No matter where I set the tracking set screw, the arm always leads. If I drop the arm before I get to platter, just to see how it moves, it moves along nicely, but when I drop it on the record, it seems that the carriage just doesn't move, or moves much slower than it should. A couple points:
Since the cartridge does seem track correctly when dropped in the space before the platter, it is almost as if it is not dropping far enough when dropping on a record, but everything seems fine as far as all the normal adjustments specified in the service manual. Arrgh. Anyone run across something like this (LesE, et al) and have any tips?
- The belt that drives the carriage roller is in place and properly oriented, and is moving the roller assembly.
- The threaded lift pin is clear of the plate that lifts it, so no drag there.
- THe carriage moves freely if I move it manually, and it does not feel like there is any hanging or binding.
- It doesn't matter where I drop the needle on the record, the tracking is always slow.
- The arm drop adjustment pin (can't remember the name of it) is clear too, and adjusted correctly.
- I can see the tracking wheel is rotating, so it is making contact with the roller and spinning.
