Ivanthetoler
Hi all! I have a ST7 TT that needs some help. I replaced the three caps and cleaned all pots but only in 33rpm mode the system has a nasty speedup and slowdown with a wow/flutter of 4 to 15! In 45rpm mode the TT is rock solid. I've swapped the two fine control pots thinking it was the issue but same result.
If the motor was an issue would it make sense that it works in the 45rpm circuit? Otherwise, any advice on where I should start to investigate the 33rpm issue?
Thank you!
Ivan
Thank you!
Ivan
