Harman Kardon T 224
aldous
Any suggestions for a amp for a newly acquired Harman Kardon T 224 tube tuner? I have found AK very helpful and informative.
In case you didn't already pick up the owners manual for your tuner:
http://manuals.harman.com/HK/Owner's Manual/Duet-T224.pdf
In terms of "modern" FM, this is a mono tuner, and will require an outboard MPX adapter if you wish to use it for MPX stereo. You'll probably find it perfectly satisfying in mono, tho'.
The A-224 "Trio" would in fact be a nice match if you can track one down. The non-"Citation" hk tube amps don't tend to be wallet-busters.
http://manuals.harman.com/HK/Owner's Manual/TrioA224om.pdf
