AmCan
Oh dear.
What? WD-40 is lubricant.
Oh dear.
What? WD-40 is lubricant.I sprayed it right into the motor pulley. Could that have damaged it? I though WD-40 was good for everything :screwy: It certainly was grinding and not spinning right before I sprayed it. I didn't know I could open up the motor assembly at the time and lube it that way.
There have been a few threads on here about the quartz sounding slow or unstable . I have a mint T65 that I picked up last month that sounds slow to me when the quartz is on lock. A few of us T owners agree that the sound is steady when the quartz is off. If you ask me -- quartz lock and belt driven TT are somewhat redundant.
I understand that the speed in QL was "trimmed" by motor pulley selection, that just sounds unlikely and wrong but I know that the particular belt used will make a difference how this TT performs.
I'd do the fuse box gimbal damping mod first, the ITO arm demands it;
http://audiokarma.org/forums/showpost.php?p=5595799&postcount=59
http://audiokarma.org/forums/showpost.php?p=5598877&postcount=68
Full mod thread; http://audiokarma.org/forums/showthread.php?p=3318000#post3318000
Thanks. I make my own custom isolation footers out of silicone but it is a good idea to brush silicon on the suspension springs. Here is a forum on the isolation devices I make and use with my TT.
http://www.canuckaudiomart.com/forum/viewtopic.php?f=12&t=24636
What cartridge do you use?
I just pulled the trigger on an Ebay vintage cartridge too, an SAE 1000e. Its an MC cartridge with a high enough load impedance to be used with a MM system. Should be a giant killer for the price. Thanks for the damping advice I am going to build something to sit on top of the tonearm. What are you filling it with? Silicone fluid?I'm presently using one of the $20 e-Bay Ortofon/Digitrac 200 NE 'tombstone' tipped carts.
As my signature says, I'm using a Shure V15 III & Jico SAS combo on my T55C. Resonance frequency is at 8Hz which is perfectly acceptable, and it sounds wonderful.So I thought I'd ask to see what other HK T-60 owners are using with their Linn Arms.
There are no pics or even a decent description of these feet at that URL. How do you make them and what do they look like?
They are made from a high grade non-adhesive silicone and are cylindrical, which is an ideal shape because they create nonlinearity, which means they have adaptability to their frequency response. I mix, de-air, pour, de-mold, and trim the silicone. I have cylinder shape molds that I use to create the shape, plus vacuum chamber and compressor for de-airing.
This is what they look like
http://www.canuckaudiomart.com/details/648992644-speaker__amplifier_isolation_footers/
Do they just sit under the gear or can they be permanently screwed in to replace old feet? If the latter, I'll probably be getting back to you when I finally tackle my Mitsubishi LT-20 overhaul, as one of its feet has fallen apart.
... Haven't ordered a FBM 25.75 yet ... not using the table at the moment ... although I did give it a quick spin the other day with a new ADC QLM36 MkIII![]()
