harman/kardon T65 Cracked Arm Repair
elverado
I got lucky early in my audiophilia and bought a used HK T65 at an audio shop around 2001 for $100 (no center weight or dust cover ... oh well). I used this with my tube amp and NAD preamp for years and loved it to death - and thought all TT's were this good.
Then went through a move 8 years ago and while I guarded it with my life during transport, it managed to have a lamp fall on it during move-in and cracked the carbon tonearm pipe in half. Everything else works but you can picture the headshell loose on the platter and wires dangling. Screams ensued, and I then put it in storage and bought a midgrade 80's Pioneer Pl-200 that I transferred my cartridge over to.
Now I'm buying more records, looking to upgrade, and checked in on possibility of selling the T65 for parts to fund a nicer table. But digging online I've learned this table has shot up in value and is really a nice table. So I'd like to buy a whole new tonearm - but it seems the people who buy standalone tonearms spend $500 - infinity on them. And if I'd pay that I'd want to make sure the physical mounting was clean and solid, which could be a crapshoot. So then I'm thinking could I just buy a pipe and headshell connection by themselves ... but those tend to match specific tables. And I don't know how I'd unglue it from the base. I"m pretty handy but don't want to have to be sawing and gluing if it'll be giving me a constant worry of if I made it sound worse. Another thought is buying a T20 (low end version of same) on eBay since I hear the micro-race tone arms are the same across models. Then swapping it out and selling the T20 for parts.
What would you do if you were in my spot? I can't really justify $500 on a tonearm now and if I do is it going to be a frankentable in a good or bad way? Thoughts?
I have a T55C and share your enthusiasm for these tables. Because of the very nice semiauto mechanism, I would agree that finding another HK tonearm from a donor turntable is the best way to go. You might be able to replace just the broken tube, or you could replace much or all of the tonearm assembly, especially if the bearings also suffered damage from the accident.
The T65 was the top table from this series, and is worth rebuilding if possible. Someone else will have to tell you how many other tables (if any) in the line shared the exact same tonearm.
Good luck getting it fixed!
Thanks for your feedback. I actually dug into it deeper and realize that the tapered tube is intact - it's the headshell socket and wires that are damaged. Now to find one of those without having to buy a donor table ...
Unable to find any source online for a straight arm headshell female mount, I got lucky and bought a donor arm piece off eBay: http://www.ebay.com/itm/301864573002 Based on the double screws on this and my table - and it being a common sight on straight armed turntables of that era - I'm hoping it's a straight swap. We'll see.
So I'll be swapping just this piece (straight armed headshell mount?) and wires from the donor part - not the arm tube (which is tapered on the t65c)
