infullview
I have a 15 inch woofer from a W70E that someone applied to much power to for a sustained amount of time. The speaker isn't burned out, but it's rubbing when you press it in gently. I was able to unbolt the magnet structure to inspect the VC to see what happened. The VC wire got hot enough to melt the epoxy coating and allow a portion of the winding to 'tilt', or pull away on one side of the coil. At the same time, the heated epoxy also deformed the VC form. It now rubs against the pole piece when you push the cone in. Since I have complete access to the VC, I thought I might be able to repair the VC by heating it back up and using a solid piece of aluminum round to reform it.
I located some 2 inch round solid aluminum stock on e-pay. I will polish the end of the stock to a near mirror finish to prevent sticking before attempting this repair. Worst case, if this doesn't work I can always try my hand a winding a new coil using this as a form. The price of admission to try out this hair brained idea was 20 bucks so not a huge loss if it doesn't work.
If I'm successful at making the VC round again, I will add a new coat of high temperature epoxy on the coil to prevent anything from moving again. I will follow up with results pro or con after I have given this a shot.
Please post if you, or anyone you know has attempted any kind of repair like this.
