SX 550 switch ... or a Noble replacement ?
Picked up a SX 550.
Broken glass, and shell of 2 knobs missing.
10 euro.
Could not withstand the challenge and bought.
Powered up, on the dim bulb. making a lot of noise, but non the less.
Even played on direct AC. Went for the recap. (caps in tha house)
Checked the transistors. aw, a lot degraded.
Replaced and reordered.
Then, having checked the info here, went for the switch..
But, my switch is a noble. But dear, not only the frontplate needs to be taken off, all other sub-frontplates as well, and even that is not enough to get the F ehr darling out....
Turned out , along with all the subplates, also the dial scale has to be loosened and the power transformator kicked out...
Anyways, a little too much force and there it was... a broken wafer...
I ignored my brute force and ignorance and went on to check the power switch...
as, I noticed before, the solder contacts , both on the print and on the housing of the power switch were "worked on " insides were clean on first sight, but the buttons in the housing were black. Cleaning revealed a thin layer of some kind of lubrication... Probably not the good stuff... Here's where a lot of trouble starts. When people put in **** that lays a film on the contacts!
cleaned them mechanically.
Next step repairing the waver... Cut out a piece of plexi glass to give strength to a reassemble with glue..
Cleaned up the copper leads on the print with a proxxon (multitool) and a mini ironbrush
Glued the plexi glass part together with the glued waverparts with bison 2 components glue. First tried to glue two parts of plexi. That turned to be rock solid after 20 minutes. First attempt went haywire. While i took the time to reconnect the tracings on the waver with halfconducterleadclippings and solder, I realized the plexi was still moving. The waver itself, by now was jointed together by glue and soldering though.
Turned out that I used too much glue out of the dubble seringe. cleaned the surfaces, dried them and made a mix of the two component glue on a jar lid, and applied thin to 1 surface only and reglued.
With the nob on it I could hear the switch doing it's work.
(be sure the "driver" of the switch is before the micro handle otherwise, it will not switch the power after reassemble)
Meanwhile I discover a transistor, a cap and a tantalum, all, hidden just behind the faceplate and subfaceplate. Without this "major surgery"I would not have spotted them.
I worked from sight, and made a sketchy map with layout and directions from the transistors., so I do not have to think EBC, etc.
Ok, "repaired waver and cleaned switch" final : I admit not a beauty, but as I hope to find out soon ; functional
Tomorrow I get the ordered transistor replacements.
The outputs ; D526 seemed ok, till I searched for the D526-O
The're rated higher so, they fell below the specs...
It IS a lot easier to make a seperate switch by cutting the wires to the combiswitch and place them above the phone plug. But that might have bad side effects ? - if you do maybe take out the phono plug all together and make a power switch there.
Ok folks , thats all for now.
