SimonSilan
Good to be here. Finally. Long time user of the massive combined knowledge on the site.
Time to get a bit more serious as I have a few days free (don’t we all
Working on my last two sets of speakers. Yup I truly believe I’ve reached that point. Of wanting to just sit n listen and forget about the ‘upgraditis’ I’ve suffered (andmost definitely enjoyed) for decades
Have two projects
Both cabinets are built and awaiting drivers and either passive or active crossovers (most likely)
I was fortunate to obtain a set of Augspurgers 2x15” large Monitors
They are now fitted with JBL 2220a and BMS 4590 through EmilarEH500s. Just figuring out how to use a Driverack on those as we speak
My question, good sirs, is about suitable (non original) drivers for a set of Canadian Made Vitavox KHorns (late 50s I believe)
As with the Augspurgers I purchased these as empty cabs. Apparently the original Vitavox drivers got the guy a down payment on his new condo !
So I have a cpl if ideas and options and would be seriously grateful if anyone would care to chime in with yays or nays
Could go active with these too
Although a high quality passive would probably be preferred as I’d like to power them with a 70w/ch JJ828
Here is what I have ‘available’ to go into n onto the KHorns
Woofers.
EVM15L
18 Sound 15LW1401
Celestion G15-150
Beyma 15KX (coaxial but good bottom)
TAD 1603 (being held by a friend for me should they work)
JBL 2235
From my meagre research it seems the TADs aren’t that far off the orig Klipsch E33 in VAS, Fs,Qts,Xmax
But of course there’s the impedance difference
Now this may be sacrilegious to some but I have a desire to go and do something a little different with the mid/hi side of things
Trying to use what I have on the shelf here so bare with me
Could this work??
Altec 802-8G on 511B for mids (the ever important vocal range)
ESS Heils from the AMT6 Pro (4 per side) for the highs
I’m sure many may question the need to add in the Heils. I’m all ears.
But I must say I’ve actually considered using them rather than the Altec! Listening to Annie Lennox sing Everytime we say Goodbye through those tweeters was a high water mark for me
So !!!
2 Way?
3 Way?
And What Way??
I’m concerned that the woofer section of the KHorn won’t want to go up to 800hz or so if I go 2 Way with Heils!
But the woofer choice is obviously a big part of the equation
Wow what an essay
Forgive me
Cheers from sunny Ontario!!!!!
Simon
Have two projects
Woofers.
EVM15L
18 Sound 15LW1401
Celestion G15-150
JBL 2235
Could this work??
So !!!
2 Way?
3 Way?
And What Way??
Wow what an essay
Forgive me
Simon
