Wow, thanks for all the comments! I'm still learning how to run this chat board, so bear with me if it gets tedious.
With the amp disconnected from the preamp raising the volume should have no effect!
Typically true, dr, but not the case in this amp, the tone and volume controls are on the Audio board with the outputs. I'll try to post the schematic, but i was having trouble with size and formatting. Please read my long winded report on page one.
I also note there could be trouble sticking this preamp into another amp, so I used a small mixer in between, and used a tiny toy computer sound amp. I had success, the preamp worked OK using the Aux input. There was no wup-wup in the phonos 1,2.
[How are you separating pre and main? There is no main/pre connection in this amp.]
There are preamp out/power amp in RCA jacks on the back panel of the KR-5600. There are shunts between them. I have run them through a graphic eq before. They do not show up on the schematic though. If you can view the schematic, notice the pre amp is two IC's and little else.
Thanks for the guidance, dr audio. I have been monitoring bias as the temp increased, and it went very high, (which I quickly shut down!) maybe in the hundreds of mv? I shut down in a panic when I found it. I can retry under control and report the results. DC offset has been superb, under 10mv on both channels. Thanks for the tips on checking ground continuity too, I sure will!
No bad caps to report, nothing smoked. Did not find caps inverted after four or five times through the board. Wish I did and that was it!
enaldo, I had not changed any transistors before I found the problem. I changed 4 transistors in response to the problem, and some diodes too. The transistors were common c945's and a733's, widely used and reported in AK, and sourced through Mouser. I checked pinouts with a cheap chinese semi tester, comparing them to the originals. I also checked in data sheets, in AK, and they were etched on the pcb. There were no changes noticed after the swap.
edit - I used the recommended a733C and c945C types with the center collector to drop right in.
sregor - this circuit has the two 3.3's, but I had already changed them to Nichicon PW's. I did use .47 film caps on the inputs . There are also some non-polarized electrolytics (is that an oxymoron?) on the board.
The Audio board makes the noise and oscillates by itself, separate from the pre amp. When it is cold, every voltage I have checked seemd well within normal limits. I mean 39v for a 38.5 b+ rail, 14.2v for a 14.1v spec, .68v for a .75spec. Nothing crazy. I'm taking measure of the diff pair, pre divers and bias trannies now. Hope to find it there!
Thanks so much for the discussion! Y'all are great! Now, how do I post the schematic?
