Hdmi cables
91firebird
Well this has been a on going debate,to me better hdmi cables do work better,last longer,better audio video,for sure better built.
i have had a few Cheap cables go bad,the contacts and wires break at the plug.hell I thought my Samsung led tv bad only a year old
turned out be 2 bad cheap hdmi cables,now do you need big buck cables ya for bragging rights,hell you can spend way over a grand for a cables,seen some more than the tv.I mean I run 20.00 hdmi cables running ge ultras right now work great for 15.00 .have had3 cables go bad all at the plug,wires broke.wont Say where I got them who Made them.they do curve some coming out of the amp but very slight.so got a new tv before trying 3 different hdmi cables tv ok,wife pissed off I am stupid life goes on.
Never mind !
I doubt any response from me concerning over 10 yrs. of zero failures purchasing and using multiple brand HDMI cables in 7 rooms of my house`s A/V/security camera systems is worth the effort !
I will say this, if the HDMI cable in use needs to make a sharp turn exiting the TV or source`s jack in it`s installation, there are available to purchase right/left or up down orientation male to female HDMI connection adaptors" to prevent the undesired sharp bending (minimum allowed radius bend) that is a no-no for those multipin usually molded connector end HF high speed data cables for video/audio !
I bought a high-spec HDMI cable for my projector. It is a long run and had to be snaked through the ceiling. I have no interest in ever replacing it.
I had a short HDMI cable go bad on my computer. The one I have now (a premium brand) has a connector issue. Sometimes the screen will just be green I rattle the wire and it works fine. As with all things I think its just bad build quality. For most brands cheap to expensive they are made in one a handful of places. The quality you get is the quality of the place doing the manufacturing not the name on the box.
