Not sure if this belongs here or in DIY, but I'll start here.
I'm considering designing and building a headphone amp. A very capable headphone amp. Maybe even an over the top headphone amp. Actually, it will be a 'trial run' before I go after designing a power amplifier.
My question is what range of headphone impedances and power ratings should I consider? I know headphones range anywhere from as low as 8 Ohms to as much as maybe 600 Ohms. Is higher than that common?
I currently have AKG K-701s. They are 62 Ohms, with 200 mW maximum power rating. That implies they need about 10 Vp-p signal swing and 80 mA peak current to drive them to full power. Higher impedance phones will need a higher voltage to drive them, and lower impedance phones will need more current.
Beyerdynamic DT-880 are 600 Ohm at 100 mW phones, so they need 22 Vp-p at 20 mA.
I don't see much in the way of 8 Ohm specs, but even assuming a totally absurd power rating of 2 W, the current required would be 700 mA peak. What is the maximum power level I should budget for? What are the most power hungry (least efficient) phones? I don't need to cover every possible phone, just the range I am most likely to ever want to use.
Terry
Terry
