Mat86
Having a balance issue and feel I'm at a wall
I recently broke my headphone plug and had to solder a new plug about a month ago. Then I broke it again last night just in normal use, the ground wires came loose, so I redid it much more secure. I also reflowed the L (Tip) connection while I was in there because it looked kinda weak and I didn't want to have another accident.
Today I'm listening and notice on some songs there's a channel imbalance, particularly with vocals, with the left channel being slightly louder
- I did a bunch of listening tests and couldnt notice imbalances generally, but I did try playing music or static with my amp at zero and rolling volume up, and did find the L side was audible first
- I reversed L/R on my source and the L side stayed louder
- I reversed the Seinnheiser connections on my headphone drivers, and the imbalance switched
So I know it's not the source (no change) and not the drivers (they switched when reversing the connectors)
I then tested resistance (while plugged into the 300ohm headphones) with one probe on the plug to Sleeve (negative) and one to lead. With 2k selected, Left measures 0.317 and Right measures 0.319. (and I tested it again out of boredom after writing this and one was .299 and the other .300) If I do a continuity test from T/R/S to the pins on the other end, they read the same, ~.23 (if that even means anything)
How is this possible and how can I test further to figure out what's causing this? I have a multimeter but am very novice with it outside of continuity testing, and dont want to just randomly disassemble and mess with soldering without a clear goal or way of measuring whats going on. Is the problem the louder one, or the quieter one?
EDIT: I should add, I just had a moment of clarity, but I thought there was a channel imbalance prior to even touching anything last night. The connection broke as I was plugging it in and out of different amps investigating a belief that drums sounded slightly off center. Not sure if that means something else is going on here, or just a red herring
