Dave expressed my take on this very well. I just verified, by looking at the MC30 schematic... there is definitely a power-take-off socket for this use, in these amps, made to run the McIntosh C4 or C8 preamp... so you should be fine.
The same applies to stuff like Heathkit W4 and W5 amps... both of those were made to take the WA-P2, so they can handle some extra heater current within the amp, if that external preamp is not connected. The WA-P2 takes 9/10 of an amp on heaters (2- 12AX7s and a 12AU7)... so, you can use KT66s in place of the 6L6s in those, too. Or, in the W5, you can change out the 12AU7s for 12BH7s, as long as you use 6L6s (changing to 12BH7s AND using KT66s would be too much current total- one or the other is OK)...
As Tom mentioned, you may have to change the cathode bias resistor to keep current in check. I had to do this, when putting GL KT66s into a pair of Heathkit W5s- they biased up a bit "hotter" than the 7581/6L6GC type tubes, in the case I had on hand...
Regards,
Gordon.
