Heath W7 bias setting
kahlfin1k
Well-Known Member
I have a pair of W7's I'm restoring for a customer and I can't find a complete manual with the bias setting procedure. I can set it by measuring the negative grid voltage and setting to the correct value but it doesn't give any meaningful reading at test points to ground or the 8 ohm speaker terminal (like some other heath models which would usually be like 1.5V). I have no problem setting the bias like this but would like to be able to inform the customer of the method for setting the bias without taking off the bottom and probing around! I guess it's possible there's a problem with the test point circuit but before I troubleshoot that I'd like to see what the original method per the manual is.
I'd greatly appreciate any info or better yet a copy of the complete manual!
Thanks!
hi, i have the manual and will look for it later on today and get back to you on the bias setup instructions if i can find it.i also might have it scanned and stored on a external hard drive and if i do ill email it to you.regards,
chris
How do these things sound guys?
Well I haven't listened to them on anything but my test speakers but after restoring them (all new caps, etc.) and fixing some torture they'd gone through in the past they sound very nice. Definitely one of the quietest tube amps I've heard. Literally not even any audible hiss let alone hum. You really have to see the iron on these things to believe it. Without a doubt the beefiest OPT I've ever seen for a pair of EL34s. I definitely believe these can put out the 55 watts they're rated at. Full wave solid state rectifier, ~500V B+, they're definitely beasts!
The guy I'm fixing them for has used them as his mains for a long time I think and swears by them and he has a whole mess of Heath and Dynaco high power EL34 and 6L6 amps. If I needed the power I would definitely consider a pair if the price was right!
