Heathkit AA-100 question
Dswankey
Lunatic Member
Here's hoping there's some Heathkit AA-100 owners here who can answer a question for me.
What's the deal with the left channel on this?
It's been running like a champ since being serviced but it seems as though the left channel is weaker then the right.
I've been playing with the separation and balance knobs, I have the adjustments on the bottom panel set equally yet it still seems as though I can't get the sound to be even.
Any help, insight suggestions would be appreciated.
Does swapping the power tubes help?
Swapping the L and R source cables?
Swapping the drive/splitter tubes?
Swapping the preamp tubes around?
Check all the resistors in the power amp section.
Whenever one does this, my first suspect is the screen resistor (820K) on the 7199 tubes. I've seen them read as high as 4 meg, when they go bad. This takes away almost all the 'drive' from the output driver tube, leading to weak sound.
I've also seen the 220K plate resistor in that same circuit go bad. And even a bad 22K 1w phase inverter resistor (there's two per 7199- if one is bad, I usually replace all of them with 2w resistors for better durability).
Regards,
Gordon.
Regards,
Gordon.
Spot on!
Check any resistors around the last two tubes. And replacement resistors, whilst cheap and don't quite look original if you are into that, will bring things back to original specifications. Don't forget to check (read: replace) the coupling capacitors. If they are Pyramid, they may be paper and very leaky.
Thanks guys for the reply, I'm going to see my tech later and I'll be sure to ask him to address this.
You might have the tech make sure the balance control is really set to the center electrically, e.g. find equal output from each channel and then loosen the set screw on the knob and set for center.
I took my iPad up there to show him the suggestions from this thread and he said to bring up tomorrow and he'll go over it with a fine tooth comb to pinpoint the issue. On another note is it me or would you say this amp is rated conservatively at 25W? it's pretty beefy to my ears.
