Hello,
Could someone please advise me? My Heathkit AA-100 was working after I made the following modifications: I replaced the selenium rectifier with a 1N4007 diode and used an 8.2 kΩ dropping resistor. I measured -18 V at the test point after the resistor and approximately -18.2 V at pin 6 of the new Tung-Sol 7591A tubes (with a 10 kΩ dropping resistor, I had measured just over -17 V at pin 6 and -16 V after the resistor). I also replaced the 470 kΩ resistors with the recommended 220 kΩ ones and increased the coupling capacitors to 0.22 µF. The unit was working. Later, I acquired a digital bias meter, which showed a reading of around 70 mA for each 7591 tube. I reduced the current to the required 35 mA by swapping the 8.2 kΩ dropping resistor for a 5.6 kΩ one, but the rectifier tube subsequently failed. Any advice would be greatly appreciated.
Thank you
Zdenek
Thank you
Zdenek
