These units live on! I recently decided to restore my AA1800 & its smaller sibling, the AA1600. Replaced all the electrolytics, the power supply caps, upgraded the diode bridge, replaced the high wattage resistors, and full set of new matched output transistors on both units.
Years ago, I had a conversation with the Heath engineering tech from the AA1800 line and he advised lowering the output stage emitter resistors to 0.1 ohms as that was what the design engineer originally wanted but cost, availability and setup adjustment pushed them to the higher value. He also stated that they decided to take an AA1800 he had just built from a kit pulled off the production line and see just what it was capable of doing. As the power supply limits max power to somewhere between 1000W and 1200W, they decided to pull one amp out and give the remaining channel the entire power supply. He said that at 800W with no clipping or failure was where they called it done. Of course, there is no way the amp could do this continously, but this is why it was rated conservatively at 250W with 2.5db dynamic headroom (most measured reviews of the time found at least 3db of headroom.
The reason for my overhaul is the amp pair are going to be used in horizontal biamp setting. I'm splitting the stereo signal into pairs per channel, <350Hz / >350Hz, with the AA1800 getting the lower band with the AA1600 handling the upper. I used xkit's XOVER-2 to handle the active crossover duty. The XOVER-2 active crossovers are centered on 350Hz (B&W provided the appropriate crossover point for biamping the N802s). Other than removing the bridging links on the 802 inputs, no further changes were made to the speakers.
I'm driving the system from the latest Eversolo DMP-A8 Gen2 Master Edition. (My concession to digital)
The final piece of the sonic equation are my B&W Nautilus 802s connected using KnuKonceptz's 8AWG braided cables.
The result.....WOW! I had read about the benefits of biamping these B&W speakers for years, but the planets didn't align until now. The floor of the system is dead silence...blackness. The lower end simply is breathtaking. Bass simply flows like warm honey, rich, rock solid, effortless. The mid/tweeter range exhibits complete control, no solid state harshness period. Absolutely crystal clear clarity. Even at volumes bordering on uncomfortable, neither amp has indicated full output even for an instant.
Granted the B&W N802s are no small contributer to the end result, but without the proper amps feeding them, which the Heath amps clearly meet, the sonic experience would suffer.
