HeathKit AD-1013 Audio Scope
ThreePhase
Hi All:
I just picked up a Heathkit AD-1013 Audio Scope in great physical condition and it actually works fine - except the scope trace will not focus to a fine line.
I have little info for this unit, other than a rather poor diagram i found on the internet, so i thought i would post this request for any experience someone on this site may have had with one of these units or possibly copy of a service manual and/or assembly manual. I've been checking e-bay but no luck so far. I have checked the video tube via tube tester, and have not found any obvious burned or failed components.
I haven't seen too many posts here on this unit and being new to this forum I'm not sure this is the right place for this equipment but i thought that perhaps i would submit this post.
Any help or info is appreciated!
3P
The first suggestion often offered here is to look for a H.W. Sams Photofact file on that unit, and get a copy of that manual. No guarantee Sams will have it.
The best publication to get, however, is an original assembly/service/maintenance manual that came with the kit and you can contact Heath about that.
The Sams Photofacts are excellent too, though.
Doug
All - thanks for the suggestions. Alan I took a look at the link you provided and that is a very clear print - looks like the actual part numbers and values are also included.
This print should provide me with enough info to get started on this unit.
Thanks again for the suggestions!
3P
